Does any1 know where I can get a new or used brake booster for my 1971 Datsun 240z? I purchased one from Autozone and the one i got the shaft was too big. My original cleavage pin didnt work on it so i took it back. Do all the remanufactored brake boosters not come with the cleavage pin? And do they all come with larger shatfs compared to the originals? Whats the deal??
Thanks
Keith
https://www.classiczcars.com/forums/topic/22304-brake-booster-help/
You need to swap over the pieces from your booster. I did the same thing when I swapped in a 280Z booster. There is only the jam nut, clevis and clevis pin. The threaded rod out of the booster should be the same size.
