Posted November 13, 200618 yr comment_189483 Does any1 know where I can get a new or used brake booster for my 1971 Datsun 240z? I purchased one from Autozone and the one i got the shaft was too big. My original cleavage pin didnt work on it so i took it back. Do all the remanufactored brake boosters not come with the cleavage pin? And do they all come with larger shatfs compared to the originals? Whats the deal??Thanks Keith Link to comment https://www.classiczcars.com/forums/topic/22304-brake-booster-help/ Share on other sites More sharing options...
November 14, 200618 yr comment_189497 You need to swap over the pieces from your booster. I did the same thing when I swapped in a 280Z booster. There is only the jam nut, clevis and clevis pin. The threaded rod out of the booster should be the same size. Link to comment https://www.classiczcars.com/forums/topic/22304-brake-booster-help/#findComment-189497 Share on other sites More sharing options...
November 14, 200618 yr comment_189553 CARDONE INDUSTRIES Part No: 53-5245 Try O'Reilly Auto Parts Keith Link to comment https://www.classiczcars.com/forums/topic/22304-brake-booster-help/#findComment-189553 Share on other sites More sharing options...
November 14, 200618 yr comment_189557 kcoke said: ...... I purchased one from Autozone and .... i got the shaft ....... The two seem to go hand in hand when purchasing Datsun parts from there. Link to comment https://www.classiczcars.com/forums/topic/22304-brake-booster-help/#findComment-189557 Share on other sites More sharing options...
