Posted November 13, 200618 yr comment_189484 Does anyone know which brand or where to go, Ground control , Motorsport ?? And is there a real advantage, It already handles like a go-cart with eibach springs and tokiko struts 16" panasports, I just want to lower the front more?? Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/ Share on other sites More sharing options...
November 14, 200618 yr comment_189515 There is alot of work involved in setting up a set of coilovers, but it is well worth the hassle. I personally recomend Ground Control, but any kit should be just fine. Gotta remember it is nothing more than a threaded sleeve and a collar. Everybody uses the same upper spring perch and you can buy anybodys springs. Do a search on these forums for more detailed info, it has been talked about alot here, and on HybridZ.org Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189515 Share on other sites More sharing options...
November 14, 200618 yr comment_189518 If you're going any lower than the aftermarket springs go, you'll probably want to section the struts to retain some bump travel. Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189518 Share on other sites More sharing options...
November 14, 200618 yr comment_189529 Here's a set for less (at least at the time of this posting):http://cgi.ebay.com/ebaymotors/240Z-Datsun-Eibach-Progressive-Rate-Spring-Set-240-Z_W0QQcmdZViewItemQQcategoryZ33582QQihZ010QQitemZ200045925977QQrdZ1 Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189529 Share on other sites More sharing options...
November 14, 200618 yr comment_189582 I'll toot my own horn:http://www.betamotorsports.com/products/240StrutKit.html Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189582 Share on other sites More sharing options...
November 14, 200618 yr comment_189605 John Coffey said: I'll toot my own horn:http://www.betamotorsports.com/products/240StrutKit.htmlGreat Stuff from Beta Motorsports. Easiest way to get to where you want to go. Coilovers already mounted on shortened struts with a selection of insert types to choose from, plus it includes SCCA Street Prepared legal Camber Plates. Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189605 Share on other sites More sharing options...
November 15, 200618 yr comment_189662 How in the heck do those camber plates mount up to the shock towers. Got any pics of them mounted? Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189662 Share on other sites More sharing options...
November 15, 200618 yr comment_189692 They sit underneath the top of the strut tower and are held in place by the two stainless bolts. No need to cut the towers. Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189692 Share on other sites More sharing options...
November 15, 200618 yr comment_189697 I have eibach springs all round with adjustable platforms,well worth doing Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189697 Share on other sites More sharing options...
November 18, 200618 yr Author comment_189843 Dtsnlvrs said: There is alot of work involved in setting up a set of coilovers, but it is well worth the hassle. I personally recomend Ground Control, but any kit should be just fine. Gotta remember it is nothing more than a threaded sleeve and a collar. Everybody uses the same upper spring perch and you can buy anybodys springs. Do a search on these forums for more detailed info, it has been talked about alot here, and on HybridZ.orgThanks for the info I need to do some research I guess! I see a few diff. types and alot of price diff. also, I want something good but at the same time I dont want to spend more than I have to .Thanks Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-189843 Share on other sites More sharing options...
November 23, 200618 yr comment_190310 Dtsnlvrs said: Great Stuff from Beta Motorsports. Easiest way to get to where you want to go. Coilovers already mounted on shortened struts with a selection of insert types to choose from, plus it includes SCCA Street Prepared legal Camber Plates.those look great, but the price is so high. Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-190310 Share on other sites More sharing options...
November 23, 200618 yr comment_190341 Could someone give me a little "coil over 101"?It seems to me that they are a lot like the OEM suspension that has the coil on the outside of the shock/strut mechanism.Just curiousthanks Link to comment https://www.classiczcars.com/forums/topic/22305-coilover-susp-kits/#findComment-190341 Share on other sites More sharing options...
