coilover susp kits.
There is alot of work involved in setting up a set of coilovers, but it is well worth the hassle. I personally recomend Ground Control, but any kit should be just fine. Gotta remember it is nothing more than a threaded sleeve and a collar. Everybody uses the same upper spring perch and you can buy anybodys springs. Do a search on these forums for more detailed info, it has been talked about alot here, and on HybridZ.org
Thanks for the info I need to do some research I guess! I see a few diff. types and alot of price diff. also, I want something good but at the same time I dont want to spend more than I have to .Thanks
Great Stuff from Beta Motorsports. Easiest way to get to where you want to go. Coilovers already mounted on shortened struts with a selection of insert types to choose from, plus it includes SCCA Street Prepared legal Camber Plates.
those look great, but the price is so high.
  • Who's Online   1 Member, 0 Anonymous, 370 Guests (See full list)
