November 15, 200618 yr comment_189737 WOW!!Great job. I am a big fan of SEM products. You did an amazing job.I would have never thought to use Great Stuff to fix a Dash.I guess my Dad was wrong.He always told me there are only two things you need in your tool box.1.) Duct Tape - If it moves and it's not supposed to... Apply Duct Tape2.) WD40 - If it doesnt move and it is supposed to... Spray WD40I guess now you can add:3.) Great Stuff - If it cracks fill it with Great Stuff Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189737 Share on other sites More sharing options...
November 15, 200618 yr comment_189741 Excellent job of blending in the contours and applying the finish!!! My guess is that with exposure to the regular exspansion and contractions of heating and cooling, you will likely start seeing cracks develope in or next to the repaired areas over time. In the event this does happen, just purchase a full dash cap ($100.00) and put it on. Nice work however!Tom Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189741 Share on other sites More sharing options...
November 15, 200618 yr comment_189743 Where do you get SEM products?Typically at auto body supply shops, or sometimes at better upholstery shops. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189743 Share on other sites More sharing options...
November 15, 200618 yr Author comment_189753 Very sharp for what you have in it! Looks better than it cost!Now for the real tests, time, heat, and UV.You are in agood spot for all three!WillThanks for all the feedback everyone.Yep, this repair has to pass the test of time here in the desert proving grounds. By this time next year I'll have an initial idea on how well this will holdup.Since I plan on keeping THIS Z for the rest of my life, I'll post if/when the fateful day occurs, I realize it's probably only a matter of time. My plan "B" is a Dashcap.Bruce Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189753 Share on other sites More sharing options...
November 15, 200618 yr comment_189757 looks great, Bruce!i wonder how tight the foam will hold the pieces together.let us know how it holds up in the Az sun. if it lasts, i would definitely consider following your lead.good work!! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189757 Share on other sites More sharing options...
November 15, 200618 yr comment_189759 Where do you get SEM products?Use this link to go to the "Where To Buy SEM Products" page.http://www.sem.ws/where_to_buy.phpGary S. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189759 Share on other sites More sharing options...
November 15, 200618 yr comment_189762 Excellent job!! Your dash looks great in the photos. Thanks for sharing with the club. You can get a dash redone for approx $400. New dashes, unfortunately, are around $1,500. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189762 Share on other sites More sharing options...
November 15, 200618 yr comment_189771 I'm impressed, especially as the cracks in your dash were huge, much larger than in the two Series I dashes I have. I might have to give this a try. I have a full dash cap standing by, but might try your method first. Thanks for posting. Gary D. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-189771 Share on other sites More sharing options...
April 6, 200718 yr comment_204926 any updates on how the repairs are holding up? i'm thinking about do this to my dash. thanksSimon Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-204926 Share on other sites More sharing options...
April 6, 200718 yr Author comment_204955 Simon,The dash looks the same as when I made the repairs back in November. I'd take some pictures but the car is masked for painting, (again!). Our winter weather lows range from the mid 30's to the low 40's at night but the car is stored in my garage so it never got exposed to the cold.The real test is coming up because the "mean" season is right around the corner. I'll post what happens to the dash sometime this fall.It's an economical repair in both time and money, you might want to just go for it!Bruce Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-204955 Share on other sites More sharing options...
April 7, 200718 yr comment_205034 man that dash is awsome! I have tried other methods to no avail now I have to find a bad dash to practice own good job Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-205034 Share on other sites More sharing options...
April 7, 200718 yr comment_205065 G'Day AllI have the original dash from my 1973 car in my garage. It was replaced with another some time ago. I have been wondering how to repair the original dash.Being located in regional Australia could present a problem, but can someone enlighten me on what can be done to "renew" the old one. I could then have it ready for the inevitble replacement of the current dash.I would not have the skills that Bruce has shown in doing his dash!!!Thanks for your help in anticipation.Regards, Jack Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=2#findComment-205065 Share on other sites More sharing options...
