November 29, 200717 yr comment_230169 This is awesome, im going to be refinishing a dash I picked up off ebay. For a final coat, has anyone tried a UV resistant coating? I found this but I will have to experiment on how it lookshttp://www.krylon.com/main/product_template.cfm?levelid=5&sub_levelid=8&productid=1818&content=product_details Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-230169 Share on other sites More sharing options...
November 29, 200717 yr comment_230210 You might also consider that it is a paint for HARD surfaces and it doesn't mention Vinyl. Many of us have discovered that the SEM brand does quite well without additional topcoating.2¢E Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-230210 Share on other sites More sharing options...
November 30, 200717 yr comment_230246 Alright cool, I was just wondering how it will hold up in the long run Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-230246 Share on other sites More sharing options...
January 12, 200817 yr comment_233827 Well add my name to the list of successful dash repairs. I followed Bruces instructions to the "T" and couldn't believe how nice it came out. I did my repair with the dash still in the car but with the windshield out. Not the best but it was workable. Here's a couple things I found during my repair.I drilled tiny holes at the ends of the cracks to check the crack from spreading.Make sure you remove enough of the black dash material next to the crack. Mine was warped upward. I didn't cut it far enough back and when I started to feather out the filler I broke through immediately.Make sure you have a thick enough layer of bumper repair over the crack. I sanded it too thin and when I pulled the car out in the sun it cracked again. I would try and leave at least 1/32" thickness over the crack and feather it out 2" or more on either side.I'm still amazed at how good the dash looks and how easy it was to do. I keep looking at the dash and just can't believe how good it looks.Thanks again Bruce!Derek Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-233827 Share on other sites More sharing options...
January 17, 200817 yr comment_234428 Bruce, how did this hold up to the Arizona weather? I'm thinking about doing this to my own dash, for the 3 cracks I have are getting bigger, and starting to get another... Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-234428 Share on other sites More sharing options...
February 14, 200817 yr comment_237054 Bruce, it has been well over a year since you have done your repair, any update? I am planning on following your process this weekend, but want to make sure that there isn't anything else I should know. I share the AZ sun and the damage it can cause!Thanks! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-237054 Share on other sites More sharing options...
April 17, 200817 yr comment_244366 Can anyone that's done this repair speak for its long term results? Definitley interested in this method but want to make sure it holds up. Thanks! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-244366 Share on other sites More sharing options...
April 17, 200817 yr comment_244373 Can anyone that's done this repair speak for its long term results? Definitley interested in this method but want to make sure it holds up. Thanks!I know it's not long term but mines still holding up fine from January. I'll emphasize again that the SEM bumper repair has to be at least 1/32" thick over the crack. If not it will just crack again. I speak from experience.Derek Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-244373 Share on other sites More sharing options...
May 7, 200816 yr comment_246571 Very nice finished result! j. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-246571 Share on other sites More sharing options...
May 7, 200816 yr comment_246575 Someone wanted to know how it held up? I can tell you.........beautiful 'cause I now own the car that Bruce fixed. I didn't even know it had been done! Great job Bruce....just like the entire resto you did on the rest of the car. Guy Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-246575 Share on other sites More sharing options...
May 14, 200816 yr comment_247421 The bumper repair just looks like regular old epoxy to me. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-247421 Share on other sites More sharing options...
May 15, 200816 yr comment_247427 The bumper repair just looks like regular old epoxy to me.That's surely due to this picture:http://www.classiczcars.com/forums/attachment.php?attachmentid=15045&d=1163612617But I can assure you that it isn't "regular old epoxy", regardless of what the picture seems to portray. SEM Bumper repair, IS mixed from two halves, but after curing it does retain a rubber type feel to it and does bend to a degree. "Regular old epoxy" and I presume you're referring to something such as JB Weld, or the like, cures HARD.2¢E Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=5#findComment-247427 Share on other sites More sharing options...
