March 16, 201312 yr comment_417917 I absolutely love seeing the results on this thread. Can't wait to get to mine. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-417917 Share on other sites More sharing options...
March 16, 201312 yr comment_417963 I absolutely love seeing the results on this thread. Can't wait to get to mine.Me too. This would have to be the Nr. 1 resto for result versus' time and effort. Just amazing. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-417963 Share on other sites More sharing options...
April 20, 201311 yr comment_421024 I got so excited when I found this thread. Just recently bought myself a 1972 240z started to get the dash out and everything was working smoothly until i bumped my steering column. Driver side just broke off it was very brittle. No luck in saving it now. No idea what to do now. Any suggestions? Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-421024 Share on other sites More sharing options...
April 20, 201311 yr comment_421025 got pictures of this dash? i cant imagine the whole dash broke apart just by bumping the steering column.I got so excited when I found this thread. Just recently bought myself a 1972 240z started to get the dash out and everything was working smoothly until i bumped my steering column. Driver side just broke off it was very brittle. No luck in saving it now. No idea what to do now. Any suggestions? Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-421025 Share on other sites More sharing options...
April 20, 201311 yr comment_421047 I don't have any. Went ahead and pieced it together this morning I used finishing nails for them to stick. I have it drying right now with the foam. Going to attempt to mold the missing pieces I couldn't find Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-421047 Share on other sites More sharing options...
June 26, 201311 yr comment_426422 THATS ITI am doing this next. The result are just too fantastic!!!And if it does no work, I will just slap a damn cap back on it.BRAVO everyone who has done this!!! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-426422 Share on other sites More sharing options...
March 28, 201411 yr comment_444366 Nothing like jumping onto a 4 year old thread, but I am going to do this process to 2 dashes this weekend, and will seel one...gotta raise some funds! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-444366 Share on other sites More sharing options...
April 11, 201411 yr comment_445569 Here's my progress so far - it is slow, but kids have to eat and stuff. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-445569 Share on other sites More sharing options...
April 11, 201411 yr comment_445570 And here's the Great Stuff sliced off. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-445570 Share on other sites More sharing options...
April 12, 201411 yr comment_445627 Hello. I am in the process of repairing my dash as well and I just wanted to share something. I am using the Bondo brand bumper repair kit.(similar to SEM). Yesterday I had the dash laying on my bench about 4' high and this morning when i came out to the garage it was laying on the ground. I thought for sure it was ruined. To my surprise it held up perfectly. No cracks at all. This stuff is strong and I see this as a permanent fix. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-445627 Share on other sites More sharing options...
April 14, 201411 yr comment_445740 I ended up using Evercoat flexible poly for my coating. I saw lots of posts about NAPA and Bondo, etc, but those didn't have enough product for what I was wanting. Lots o cracks. It sands well, which was a concern of mine. I will post pics as soon as I get it finished. Thanks for the inspiration! Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-445740 Share on other sites More sharing options...
April 14, 201411 yr comment_445746 I attempted a repair with SEM bumper repair and was shocked just how fast it set up. I did manage to get a butt joint bond to the vinyl on two of the three cracks. I thought this might be sufficient as I had stop drilled the ends of the cracks.The repairs last a matter of weeks before the butt joints failed and a hairline crack re-appeared. Considering the thinness of the crack, I tried filled with crazy glue filled with micro-balloons used in model aircraft. This also failed. At first I thought it was caused by heat, but over time I've noticed the cracks widen on a cold night and close up in the hot summer sun. I have come to realize that the butt joint will never be strong enough using any kind of adhesive due to the small bonding area. The would indicate a lap joint is needed by inserting a piece of plastic bridging both sides of the crack. Getting good pressure to achieve a good bond would problematic when pressing against the soft, deteriorating foam rubber.I recalled Edd China doing a front plastic bumper cover repair on Wheeler Dealers. He made a point of drilling holes on each side of the crack so that the epoxy not only spanned across the crack, but also through the hole. The Six10 material looks promising. I'm contemplating adding a substrate to for a lap joint, adding through holes, and securing the substrate with sheet metal screws while waiting for the epoxy to set up. After its sets up, I'll remove the screws and fill the holes with more Six10. Link to comment https://www.classiczcars.com/forums/topic/22325-dash-repair-processpictures/?&page=13#findComment-445746 Share on other sites More sharing options...
