Email logins are now active ×
Broken Stud - Help
bobc
The other day I noticed that the nut on the last stud on my exhaust manifold looked loose. Actually, it turned out that the stud had cracked in two. I drilled a hole in the stud and tried to pull it out with a screw extractor. Well, the screw extractor broke off in the stud flush with the broken piece. I can't get a drill to start into the screw extractor (probably because it is hardened steel).
Any ideas on where to go from here? Will I have to pull the head and take it to a machine shop? Thanks for the advice.
$#%#@!$%$- Those where my thoughts after the extractor broke!
Hate it when that happens.
I've had luck by taking a nut that is slightly larger than what would be normal for the stud and placing it over the end of the stud or over the hole where the stud was broken off flush, Then welding through the hole in the nut with a relatively high amperage MIG. This , when it works, welds the stud to the nut and also introduces heat to the stud. I then put a wrench on the nut and wiggle it. It usually comes free. Also you might try heating the nut with a torch first to introduce even more heat.
Good Luck.
Larry
When I broke the extractor, I was working on a cold engine. Anybody think it would be easier if I did this after bringing the engine up to temperature? I'm thinking about just leaving it alone. I don't hear any exhaust leaking, so until it starts, I don't see any harm in just leaving it alone. On the other hand, if I screw this up, I've damaged an e-31 head. Thoughts?
I found a broken stud on my 260 #1 cylinder under the t-stat housing.It,s not leaking and has been like this since I,ve had the car,almost a year.The break is near flush with the head and probably have to remove the manifolds to extract.I,m leaving it alone as the manifold is providing a good seal
  • Who's Online   0 Members, 0 Anonymous, 251 Guests (See full list)
