November 27, 200618 yr comment_190552 Since my Z sets for several months at a time, that's one of the reasons I run an electric pump in addition to the mechanical pump. You can prime the fuel system with the electric pump before you crank the engine over. Link to comment https://www.classiczcars.com/forums/topic/22409-fuel-pump-not-pumping-gas/?&page=2#findComment-190552 Share on other sites More sharing options...
November 27, 200618 yr comment_190556 Put a one way valve in the fuel line just ahead of the fuel pump, and it will keep prime(if you install it the right way...) If it doesn't, you probably need to tighten the clams or replace the hoses.Will Link to comment https://www.classiczcars.com/forums/topic/22409-fuel-pump-not-pumping-gas/?&page=2#findComment-190556 Share on other sites More sharing options...
November 27, 200618 yr comment_190595 ......If I wasn't afraid of using up my battery trying to start the engine, it would have eventually paumped gas into the carbs.Now I know if I let it sit for a month it will take a while for the pump to prime.Thanks guys.You should get a battery maintainer of some kind. I use one on my 320 Pickup when it sits for long periods and it keeps the battery charged. Link to comment https://www.classiczcars.com/forums/topic/22409-fuel-pump-not-pumping-gas/?&page=2#findComment-190595 Share on other sites More sharing options...
November 27, 200618 yr comment_190596 Since my Z sets for several months at a time, that's one of the reasons I run an electric pump in addition to the mechanical pump. You can prime the fuel system with the electric pump before you crank the engine over.I run a similar setup, and it works well. Link to comment https://www.classiczcars.com/forums/topic/22409-fuel-pump-not-pumping-gas/?&page=2#findComment-190596 Share on other sites More sharing options...
November 27, 200618 yr comment_190607 I was going to ask an elect. fuel pump question, but instead of hijacking...I will begin a new thread. Link to comment https://www.classiczcars.com/forums/topic/22409-fuel-pump-not-pumping-gas/?&page=2#findComment-190607 Share on other sites More sharing options...
