I you end up using Nissan factory 81-83 ZX Wheels, You must use the special Nissan lug nuts. Very few aftermarket sources are availible for this special lug nut. Other aftermarket wheels use more common lug nuts
Depending on how much you are paying for those wheels, there may be some much better options out there. I got my Konig Rewinds from Motorsport for about $550. I couldn't be happier. As mentioned, try Motorsport and eBay. If it does not specifically say its for a Z, you need 4X4.5 bolt pattern and a RWD offset. Otherwise you could get the adapters that will allow you to use FWD wheels, like for a Honda. That makes your possibilities almost limitless. The adapters can usually be found on eBay, but I think Motorsport may sell them too. You could probably find them elsewhere on the web as well.
