Posted December 8, 200618 yr comment_191931 The drivers side door on my 73 240 closes fine but it's not a tight seal, in otherwords it's closed, but it still looks like its not shut all the way. Whats the best way to adjust this? I cleaned everything and it helped with the passenger door as it now closes perfectly, but I can't get the drivers side to close all the way.Thanks for any input.Randy Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/ Share on other sites More sharing options...
December 8, 200618 yr comment_191933 Randy - The striker plate on the door frame (under the car serial plate) can be loosened slightly and adjusted inwards. The best approach is to slightly loosen the 3 bolts, close the door gently, then push the door in. Open the door, and tighten the bolts. Check the closing action - you shouldn't have to slam the door to latch it...might take a few trys to get it where you want it.GWGarrard Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-191933 Share on other sites More sharing options...
December 8, 200618 yr comment_191944 Try this tech article on door adjustment:http://classiczcars.com/forums/showthread.php?t=12484 Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-191944 Share on other sites More sharing options...
December 8, 200618 yr Author comment_191959 Thanks guys, I'll be trying these tips out later. Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-191959 Share on other sites More sharing options...
December 8, 200618 yr comment_191976 You might want to use a sharp pencil to very lightly trace the outline of the striker plate before moving it.Might. Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-191976 Share on other sites More sharing options...
December 8, 200618 yr Author comment_191998 Hey guys,I tried everything to get the door to close better, but I think it may be more serious. I took the striker plate completely off and the door still will not go flush with the body. The top looks good, maybe a little tight where the chrome around the window is, but the bottom of the door when shut I can almost get my fingers between it and the car.....Hmmmmm.Do ya'll think maybe the hinges are bent? Is the door crooked, or warped? This is all new to me. Is it hard replacing hinges, or might I need a new door.Any thoughts....Thanks,Randy Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-191998 Share on other sites More sharing options...
December 9, 200618 yr comment_192002 Could it also be that your frame is a bit tweaked too? These cars are not known for being the most rigid chassis in the world. Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192002 Share on other sites More sharing options...
December 9, 200618 yr comment_192007 Has it always been like this? Have the door seals been recently been replaced? Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192007 Share on other sites More sharing options...
December 9, 200618 yr comment_192014 It almost sounds like the front hinges are mis-aligned causing the top to be flush and the bottom to stick out. I'm not even sure if these are adjustable but my guess is that they are. You might give that a looksee. Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192014 Share on other sites More sharing options...
December 9, 200618 yr comment_192043 I've seen shims used under door hinges in certain situations. Aligning doors/panels is a pain and can easily kill a few hours.My2c Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192043 Share on other sites More sharing options...
December 9, 200618 yr comment_192044 What are the shims like? Paper thin, or thick, like 2-3mm? Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192044 Share on other sites More sharing options...
December 9, 200618 yr comment_192046 Sounds like you may have a hinge that needs adjusted. Does the door open freely? What does the gap look like at the top and bottom of the door compared to the fenders? Is the gap at the bottom of the door tappered front to back, or is it even all the way? Link to comment https://www.classiczcars.com/forums/topic/22553-door-adjustmentcan-it-fit-tighter/#findComment-192046 Share on other sites More sharing options...
