Posted December 8, 200618 yr comment_191973 I am now certain that the person who owned my Z before me messed up on the fuel line installation. He ran all 1/4 inch rubber hose and the return line is plumbed up back into the filler some strange way. Anyways, i am going to drop my tank soon and do this all over. Can anybody here please diagram or explain to me how to run proper fuel lines? Link to comment https://www.classiczcars.com/forums/topic/22557-help-with-fuel-lines/ Share on other sites More sharing options...
December 8, 200618 yr comment_191974 first of all, what car are you referring to? What engine is in it? The fuel-injected engines use 8mm (5/16 inch) fuel lines. Be sure to use fuel injection fuel lines, not the regular low-pressure stuff. Also, there is usually a hard line (steel tube) that is used for the fuel return, and it goes back into the side of the fuel fuel tank. You'll see it when you service your fuel tank. It may be blocked, which is why the return line was re-routed.While you are at it, replace all the rubber hoses that carry fuel. Any original ones must be way old & ready to split. Be aware that some of the fuel tank hoses have special bends that can't be easily duplicated.Are there any other clues you can tell to help?thx Link to comment https://www.classiczcars.com/forums/topic/22557-help-with-fuel-lines/#findComment-191974 Share on other sites More sharing options...
December 8, 200618 yr Author comment_191980 Sorry i forgot to include some details. My car is a 1972 240z and it has a semi built L24 in it. I was just wondering how they were set up originally so i can try to duplicate it as close as possible. Link to comment https://www.classiczcars.com/forums/topic/22557-help-with-fuel-lines/#findComment-191980 Share on other sites More sharing options...
December 8, 200618 yr comment_191982 I am now certain that the person who owned my Z before me messed up on the fuel line installation. He ran all 1/4 inch rubber hose and the return line is plumbed up back into the filler some strange way. Anyways, i am going to drop my tank soon and do this all over. Can anybody here please diagram or explain to me how to run proper fuel lines?Gary , first of all be sure any on the hoses you use are for fuel and are rated for gasoline . Some times people will use heater hose or vacuum line. The return port on the tank is just above the supply port and by the sending unit for the gage. There is a small line that is supposed to lead to the evap tank that is located in back of the plastic finisher on the right side rear of the interior. This line should be connected to a 3 way valve up front just below the ignition coil. It is the fresh air return to the tank that supplies air when the fuel is removed and used . You will find three vent hoses that enter the cabin from the main tank and they are connected to the evap tank. Be careful not to kink the upper 5/8'' hose where it comes off the tank . Also take care when you disconnect the main filler hose. They are SPENDY ! Gary Link to comment https://www.classiczcars.com/forums/topic/22557-help-with-fuel-lines/#findComment-191982 Share on other sites More sharing options...
December 8, 200618 yr comment_191984 Besides the Factory service manuals, I find the Mitchell's service books very helpful. The regional county Pubic Library had those. Link to comment https://www.classiczcars.com/forums/topic/22557-help-with-fuel-lines/#findComment-191984 Share on other sites More sharing options...
