Posted December 10, 200618 yr comment_192171 I was curious why the valve covers for these cars were made with a third hole? Yes, two out of the three are used for the wire looms, but what is the the third one for torwards the back of the valve cover? Link to comment https://www.classiczcars.com/forums/topic/22578-why-there-is-a-third-screw-hole-in-the-valve-covers/ Share on other sites More sharing options...
December 10, 200618 yr comment_192175 On late model 240Zs they are for the choke cables although 280Zs don't have chokes. Link to comment https://www.classiczcars.com/forums/topic/22578-why-there-is-a-third-screw-hole-in-the-valve-covers/#findComment-192175 Share on other sites More sharing options...
December 11, 200618 yr comment_192275 So what should you do with that third hole? Link to comment https://www.classiczcars.com/forums/topic/22578-why-there-is-a-third-screw-hole-in-the-valve-covers/#findComment-192275 Share on other sites More sharing options...
December 11, 200618 yr comment_192279 These engines were not only installed in the Zed remember - don't forget they were also used in the RHD, Skylines/240K/240C/260C/280C/Laurels/Patrols just to name a few. Not all of these would have rod operated accelerators so maybe the other hole was used for a cable operated accelerator on a RHD car - most all share the same rocker cover. Most of the what some consider rare big NISSAN valve/rocker covers were from these other models usually the 1980+ models. The latest model I have seen with a L6 installed was a Laurel C31 1984. Link to comment https://www.classiczcars.com/forums/topic/22578-why-there-is-a-third-screw-hole-in-the-valve-covers/#findComment-192279 Share on other sites More sharing options...
December 11, 200618 yr comment_192280 double post sorry about that. Link to comment https://www.classiczcars.com/forums/topic/22578-why-there-is-a-third-screw-hole-in-the-valve-covers/#findComment-192280 Share on other sites More sharing options...
