Posted December 13, 200618 yr comment_192567 Hi, I need some very good piston rings for my 77' Datsun 280Z FI L28. Stock bore size. I cant put my engine back together until I have these.Thanks Brendan Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/ Share on other sites More sharing options...
December 13, 200618 yr comment_192572 Cincy_280Z said: Hi, I need some very good piston rings for my 77' Datsun 280Z FI L28. Stock bore size. I cant put my engine back together until I have these.Thanks BrendanThats a fact Jack!!!! Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192572 Share on other sites More sharing options...
December 13, 200618 yr comment_192576 Here ya go-type in Piston Ring in the search box, to pluralize it (rings) gives 0 results.http://www.thezstore.com/store/merchant.mvc?10-4171 Performance Piston Ring Set, L28 Engine Standard Size $68.45 I'm sure there are others, but this is a start.While you are busy assembling, you might want to order some of these:http://kalecoauto.com/index.php?main_page=product_info&cPath=2&products_id=7http://kalecoauto.com/index.php?main_page=product_info&cPath=2&products_id=32http://kalecoauto.com/index.php?main_page=product_info&cPath=3&products_id=27http://kalecoauto.com/index.php?main_page=product_info&cPath=7&products_id=20I assume you already know about the engine oil bypass kit... Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192576 Share on other sites More sharing options...
December 14, 200618 yr comment_192582 don't reply if you have nothing to say 240Brendan--Check out this link:http://www.classiczcars.com/forums/showthread.php?t=19603&highlight=good+piston+ringsand that's just for starters...there are lots of others that popped up when I searched the forums(see next paragraph)....and check out what Zbane said above--you normally can't go wrong with purchasing stock stuff from either Nissan if the parts are available, or from MSA (Motorsport Auto) which is the www.thezstore. that is the link....I buy 75% of all my replacement parts from MSA--just bought a replacement clutch slave cause mine was leaking. They are great for that kind of part....also be sure to ask for a catalog (they are out right now they said, they'll send you a cd-rom version instead [which I actually wish i had sooner i didn't know they had them]).In the future, use the 'search forums' link at the top--i found this link by searching for 'good piston rings'.Most of the time, it's best to search for an answer to a question before posting. Some of the people that reply with great information have already answered questions and they might not want to answer it again.Just my .02 dollars. Take care, and good luck with your rebuild.Welcome to the website! Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192582 Share on other sites More sharing options...
December 14, 200618 yr comment_192583 You beat me Dave.... see what happens when I just sit there for a 1/2 hour before clicking 'send' on my reply!!:-) Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192583 Share on other sites More sharing options...
December 14, 200618 yr comment_192604 I just bought a set of piston rings, I am having my engine bored etc and the machinist ordered them the brand is "perfect circle" piston rings. Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192604 Share on other sites More sharing options...
December 14, 200618 yr comment_192611 I sent a PM with a recommendation. all the best . :knockedou Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192611 Share on other sites More sharing options...
December 15, 200618 yr Author comment_192774 . thats awesome. I love the "o" pipe exhaust. Thanks for your help. Brendan Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192774 Share on other sites More sharing options...
December 16, 200618 yr Author comment_192775 In the future said: I will from now on. I was in a hurry when I started the thread.I have some rings on the way. Brendan Link to comment https://www.classiczcars.com/forums/topic/22622-help-i-need-very-good-piston-rings-for-my-l28-fi/#findComment-192775 Share on other sites More sharing options...
