Posted December 18, 200618 yr comment_192998 i just got the car yesterday as a christmas gift all original it was running untill it was stored for 15 yrs iv changed the gas, oil, oil filter and i can get it to start up for about 5sec but the min i give gas or any thing it dies, its fuel inject which iv never dealt with them befor Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/ Share on other sites More sharing options...
December 18, 200618 yr comment_193004 Have you replaced the fuel filter? Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193004 Share on other sites More sharing options...
December 18, 200618 yr comment_193007 Fifteen years of sitting will cause a lot of crud to build up inside the tank and lines causing a loss in fuel pressure. You will most likely have to clean out or replace the gas tank. I had to do that on mine and it had only been sitting for four years. Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193007 Share on other sites More sharing options...
December 18, 200618 yr comment_193008 sblake01 said: Fifteen years of sitting will cause a lot of crud to build up inside the tank and lines causing a loss in fuel pressure. You will most likely have to clean out or replace the gas tank. I had to do that on mine and it had only been sitting for four years.I will second this opinion as there was A LOT of rust build up in my Z's tank when I got it. And it's tank was boiled before it was stored and it stayed in a garage for four years. I probably got out two full hand fulls of rust.If this doesn't work there might be a wiring issue, but since you Z runs then cut's out, it is a fuel delivery issue. The fuel injectors might also be an issue since they are fairly old. Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193008 Share on other sites More sharing options...
December 18, 200618 yr comment_193011 When you drained the gas what did it look/smell like? Was it kind of dark brown? More than likely you'll be doing some work on your fuel tank shortly...crud...crud...and more crud from all the years storage. Good news is you can send it out to be done or you can do it yourself...Do a search on fuel tank renu if you want to send it out...webdawg1 Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193011 Share on other sites More sharing options...
December 18, 200618 yr Author comment_193020 the gas i pulled out was surprisingly clean no sluge or rust came out ill clean the ijectors today and see if that helps any Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193020 Share on other sites More sharing options...
December 18, 200618 yr comment_193021 ryan said: the gas i pulled out was surprisingly clean no sluge or rust came out Because it's still in the tank! Trust us on this one. If the car sat for fifteen years, you either have to clean or replace the tank. Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193021 Share on other sites More sharing options...
December 18, 200618 yr comment_193029 yup.. just went through that..the good news is droppin the tank is EASY on these.. i had the same thing happen, the gas i drained looked ok..but wouldnt ya know, i had a pile of rust that looked like the biggest ant hill by the time i done...works great now!! Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193029 Share on other sites More sharing options...
December 20, 200618 yr comment_193206 I just went through the exact same problem and when I got it to start as soon as you touched the gas pedal it would die. the problem I had was the rotors in the fuel pump were stuck in place. Check your fuel pressure just after the filter and you should have arround 36psi. It won't rum worth a dam on less than that. If you take the pump appart make sure you mark it and put it back together properly. It's easy to mess up the location of the center disc so match mark all parts. I have old posts on this check them out. Also print yourself a copy of the Fuel Injection bible. I don't have the link for it but do a search and you will find it here. Good luck Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193206 Share on other sites More sharing options...
December 20, 200618 yr comment_193231 racebird1 said: I just went through the exact same problem and when I got it to start as soon as you touched the gas pedal it would die. the problem I had was the rotors in the fuel pump were stuck in place. Check your fuel pressure just after the filter and you should have arround 36psi. It won't rum worth a dam on less than that. If you take the pump appart make sure you mark it and put it back together properly. It's easy to mess up the location of the center disc so match mark all parts. I have old posts on this check them out. Also print yourself a copy of the Fuel Injection bible. I don't have the link for it but do a search and you will find it here. Good luckNot trying to sound like a 'doom sayer' but I'll bet your car wasn't sitting for 15 years when you developed that problem. I'd like to reitererate that you tank is most likely toast and that's what you need to look at. After I had my tank cleaned the car fired up and has been running right ever since with the original, untouched fuel pump. Check into the tank first. My experience says that your fuel pump is probably okay. Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193231 Share on other sites More sharing options...
December 22, 200618 yr Author comment_193339 sorry to say but you guyz were wrong it wasnt the tank it was just build up in the exaust Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193339 Share on other sites More sharing options...
December 22, 200618 yr comment_193341 wow i was about to blame your AFM or vacuum lines...the gas tank problem may still be there...and if it is you'll find out soon enough. Link to comment https://www.classiczcars.com/forums/topic/22668-78-280z-wont-run/#findComment-193341 Share on other sites More sharing options...
