Combo switch blues...
straitsix
The sun is setting on these combo switches, and if you're looking even for a salvage one, my point is made? What I want is to take the headlamp circuit out of there and run it through a toggle switch, running lights too. It can be done, but I would sure like some some electrical wizard to aid me.
are in the problem part of the switch, as far as I can tell. I have them out and running through a small switch down in the dash "kick" near that weird vacuum switch (--why is that thing anyways?). Things went okay for a while, but the other functions seem to overwhelm the toggled circuit, ie. blinkers... I guess I am off the ground with three wires to the toggle, which can't be good, and explains some things I have yet to understand. Might be that four wires must be involved, but the combo switch ground feeds the other functions? Maybe an "earth" ground from the toggled circuit with allow it to function in isolation? Also the headlamp/running light circuit is "off, on, on on", so with an "off, on" toggle both sets of lights must be grouped on one side, but now I am seeing the need for four wires and things are making even less sense...
  • Who's Online   1 Member, 0 Anonymous, 788 Guests (See full list)
