Hi Andrew,
yes, it takes a lot of chasing to get things from him unfortunately (it took a long time to get the moulds completed), i have him making up another front grill for me, but i am not sure how long that will take (though i am not desperate for it to happen shortly so i am not too worried).. he does get it done in the end, but it sounds like there is a lot of commercial work they do that unfortunately soaks up most of their time.
Kent
The grill is $120 or $140 I didn't write down which was the front fender and which was the grill. I didn't get a price for the bod tail.
He's charging me $270 for the four overfenders but this price was given to me after I told him I just wanted the overfenders and nothing else. Is this what you paid Kent?
Phil has finally contacted me in regards to sending them so progress is being made. I'll check with him again tomorrow and post the exact prices for all items.
Thanks for sorting this contact out as well Kent.
i am not 100% sure, but the grill is far more expensive than that i think.. around $300 maybe? there is a lot of work involved plus it includes the metal grill and brackets..
$270 sounds familiar for the flares too (although it was a long time ago now!)
no problems, at least all the bits are available from one place now!
The $120 & $140 prices must have been for the bob tail and the front fender/lip sorry noodle.
Tyr Phil on his mobile, you can usually get him on that unless he hasn't bought a new battery yet then you'll get him for about 2 minutes.
  • 3 weeks later...
I have just recieved my arches and I'm not too happy with the quality of them, They don't seem to fit any panels very well at all. Has anyone else bought these and had the same problems?
The front arch ones are the worst and both my panels are undamaged so it has to be the fiberglass arches that are the wrong size.
I have just realised that my front arches are modified and they are extended at the bottom to go over the 100mm x 50mm box sections that were used to strengthen the car when the roof was taken off.
It wasn't the arches after all.
I will have to send one of my arches back to get replaced as after close inspection one of the front ones has a stuffed end section. Instead of being squareish at the end it is deformed and has a pointy end that is different to the other side.
  • 4 weeks later...
