When I push in the clutch on my 70 240 (with a 78 transmission) its impossible to shift into gear (reverse or 1st), unless I let the engine run for a few minutes, in neutral. Then I can shift but its difficult.
After a little driving it shifts well, but whenever I start i go through this process. What's wrong and what should I do?
https://www.classiczcars.com/forums/topic/2271-transmission-advice/Share on other sites
