replacement Windsheild washer nozzles
TomoHawk
I think replacing the old single-jet squirters with something like this would make better use of your windsheild washer pumps. I look for a jet with dual nozzles, and attaches with a nut from underneath. It would have to fit in the slots in the air cowl, unless you intend to make it permanent, and have way to seal the metal after drilling or shaping a hole to fit the jet.
An example: VW beetle nozzle Auction
Either that, or something like the l.e.d. jet without the l.e.d. I even favour the style from a Ford Escort, which is plastic, somewhat flat, and has a fanned spray pattern.
thx
VW washer jet:
  • Who's Online   1 Member, 0 Anonymous, 592 Guests (See full list)
