What tools are absolute must haves when restoring a car?
I have a lot but I want to round out my collection for my birthday.. so far I was thinking of getting these
Angle grinder
Ball pein hammer
and a punch
What else can I add to the list?
https://www.classiczcars.com/forums/topic/22776-must-have-tools/
Dont own the welder yet... I was going to wait for my next project to buy that one. I am having the welding done on my Z by someone else. Next project will be all me though.
I have the rest of the stuff though
Digital camera.
Clear plastic ziplock bags of various sizes.
Permanent marker (fine tip).
Take images from all angles before taking any part off you car no matter how easy to remember it is.
Put all parts in plastic bags with the date they were removed.
Store all digital images of your parts in a folder on your PC with title set to the same date as that of the part in the bag. That way you will be able to take that "what part is that" to you PC and check where it was on the car.
You'll be amazed just how hard it is to recognise some parts after a year being in bags.
All electrical connections label as well. Just put a letter on each pair of connectors.
Labeling is one thing I made sure I did =)
Right now the car is totally stripped and the body work is being done at a shop.
The engine was taken out someplace and its coming to my house tomorrow and im going to clean it up so I can put it back inside the car when its ready for it.
Hopefully I will do alright putting it back together. I cleaned out the garage today so I can work on the engine pretty easily.
After not working on it for months im really excited to get going on it again
With this project I am outsourcing a lot of the work because I dont really know what im doing. I learned a lot on this project and I am seeing how some of the other stuff is done. My next project should be done completely by me. Should be a lot cheaper that way =)
  71datsunZ said:
Not too far from you... im in Piscataway.. you have an aol screen name I could talk to you on?
sorry, no aol.
but one of these days we should meet up to swap stories and hints.
Angle grinder
Ball pein hammer
and a punch
If your angel grinder is air powered you will need a decent compressor. I have a small one that has two cylinders . The kind for running a number of nailers . I will not power even a small die grinder for more than about 30 seconds. If you are thinking of spraying any primer or paint . Buy once and get a good one . Get the set of hammers , you will use all three at some point. Harbor Freight sells a body kit for around $20.00 that has the dollies and body hammers . This is also a good place to find the air tools to. The tools they carry are not up to professional grade , but for the average person they are great. I have a angle die grinder that I have used a ton . It was only about $9.00 when it goes gunny sack I will just toss it and get a new one. Gary
