Posted December 28, 200618 yr comment_193990 How many of you have converted a 240z to v8 using a kit? I would like to hear from someone that has about what kit they used and how difficult it was.-Nick Meyer Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/ Share on other sites More sharing options...
December 28, 200618 yr comment_193992 www.hybridz.org Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-193992 Share on other sites More sharing options...
December 28, 200618 yr comment_193993 Nick, you'll find that there aren't many V8 swappers on this board, you'll get much more info from the guys at HybridZ.org. Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-193993 Share on other sites More sharing options...
December 28, 200618 yr Author comment_194008 ok, thanks.-Nick Meyer Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-194008 Share on other sites More sharing options...
December 28, 200618 yr comment_194010 Hi Nick, I did the V8 swap on my 71 using the Jags That Run kit.PM me if you are looking for more information. Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-194010 Share on other sites More sharing options...
December 28, 200618 yr comment_194078 hi nick,i have an original scarab swap..it works great. but they are out of business. the jag conversion does wrk too. hooker still has the headers and they might have the motor mounts too. it just raises up the motor a bit and back a little. good luck paul Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-194078 Share on other sites More sharing options...
December 29, 200618 yr comment_194128 I have a 77 with JTR conversion. That conversion sets the motor back to the fire wall and toward the passenger side about 3/4 of an inch. It went much better than I had expected. They also have a book that goes through the whole ordeal that you can buy. It has some pretty good specs. on the parts you can build if you don't feel like buying theirs. I would recomend buying the parts unless you have a machine shop available to you. Send me an email if you want more info. I'd be glad to help. I used a 350TPI. If I did it all over again....I'd probably go LS1, but the tune port is what I had in the corner of the garage. It still is piles of fun. Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-194128 Share on other sites More sharing options...
December 29, 200618 yr comment_194132 Nick I Have A 280zx With A 400 Smallblock(bought It That Way Show Car In Alabama} And I Took It Out As It Was Twisting The Rear End Out Of The Car I Think The 6 Banger Is Best For The Car The Only Mod For The Zx Was Motor Mounts And Small Piece Cut Off Behind The Motor But Don't Do It Link to comment https://www.classiczcars.com/forums/topic/22777-v8-conversion-in-a-240z-coupe-kit/#findComment-194132 Share on other sites More sharing options...
