V8 conversion in a 240z coupe (kit)
NMeyer
hi nick,
i have an original scarab swap..it works great. but they are out of business. the jag conversion does wrk too. hooker still has the headers and they might have the motor mounts too. it just raises up the motor a bit and back a little. good luck paul
I have a 77 with JTR conversion. That conversion sets the motor back to the fire wall and toward the passenger side about 3/4 of an inch. It went much better than I had expected. They also have a book that goes through the whole ordeal that you can buy. It has some pretty good specs. on the parts you can build if you don't feel like buying theirs. I would recomend buying the parts unless you have a machine shop available to you. Send me an email if you want more info. I'd be glad to help. I used a 350TPI. If I did it all over again....I'd probably go LS1, but the tune port is what I had in the corner of the garage. It still is piles of fun.
Nick I Have A 280zx With A 400 Smallblock(bought It That Way Show Car In Alabama} And I Took It Out As It Was Twisting The Rear End Out Of The Car I Think The 6 Banger Is Best For The Car The Only Mod For The Zx Was Motor Mounts And Small Piece Cut Off Behind The Motor But Don't Do It
