Posted December 28, 200618 yr comment_193995 My newly acquired '73 240Z sounds like I'm carrying a bucket of bolts in the back seat... I'm sure the rear struts are toast and I plan to replace them (soon?). In the meantime, are there any greasing points either in the rear struts themselves or the rear suspension in general??? I greased the front end and it made a remarkable difference... Link to comment https://www.classiczcars.com/forums/topic/22778-grease-points-on-rear-suspension/ Share on other sites More sharing options...
December 28, 200618 yr comment_194015 No, nothing in the rear. Link to comment https://www.classiczcars.com/forums/topic/22778-grease-points-on-rear-suspension/#findComment-194015 Share on other sites More sharing options...
December 28, 200618 yr comment_194028 No grease points , however if you are hearing undue noise check ALL the ujoints. There are four on the half shafts. Another thing while you have the car up off the ground . Rotate the rear wheels and see it you can hear any noise or feel any vibration from the axel bearings . Gary Link to comment https://www.classiczcars.com/forums/topic/22778-grease-points-on-rear-suspension/#findComment-194028 Share on other sites More sharing options...
December 28, 200618 yr comment_194034 If the original bushings are worn or have been replaced with polyurethane, they could be the cause. The poly bushings tend to squeek a lot if improperly lubed. Link to comment https://www.classiczcars.com/forums/topic/22778-grease-points-on-rear-suspension/#findComment-194034 Share on other sites More sharing options...
