Posted December 30, 200618 yr comment_194268 What do you expert mechanics use for a ball joint extractor? I need to get the ball joint of of the steering arm and I also want to replace the trackrod-ends with new ones. Thanks Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/ Share on other sites More sharing options...
December 30, 200618 yr comment_194270 There are some previous threads on this exact topic which were very helpful .A few posts mention the reverse threads on the tie rod ends also. Just search ball joint and it's all there . Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194270 Share on other sites More sharing options...
December 30, 200618 yr Author comment_194272 Thanks. I searched for Ball Joint Extractor, but that search returned articles about broken bolts and taps only. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194272 Share on other sites More sharing options...
December 30, 200618 yr comment_194273 Search just" ball joint."I was looking through those last night as I am about to do some more front end work. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194273 Share on other sites More sharing options...
December 30, 200618 yr Author comment_194275 Would one like this do the trick on Z car ball joints? Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194275 Share on other sites More sharing options...
December 30, 200618 yr comment_194291 Actually, on the early Z cars the main ball joint is pressed into the steering arm. The steering arm bolts to the bottom of the strut, and the other side of the ball joint bolts to the lower control arm.You do have to remove the ball joint for the steering rack from the steering arm on the car, but the main ball joint can be pressed out with an arbor press after you unbolt the ball joint - steering arm assembly from the strut and arm.It think that I just used a "pickle fork" to get the tie-rod end loose from the steering arm, but the one you have photographed should work even better. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194291 Share on other sites More sharing options...
December 30, 200618 yr comment_194317 If you're not reusing the ball joint just get a pickle fork. That tool shown above is great and won't tear up the boots, but if you're replacing them anyway the pickle fork usually costs about $3 at your local auto parts store and does the job just fine. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194317 Share on other sites More sharing options...
December 31, 200618 yr comment_194392 I just redid all mine this last summer (New factory Nissan Ball Joints & Tie Rod Ends.) Like Jon mentioned, if your replacing them with new ones which it sounds like you are because they are worn out, then a good pickle fork kit will suit your needs perfectly. I have the pickle fork set that can be used both in an air hammer or pound on them with a regular hammer. My best advise to you is to get the forks that can be used with an air hammer which is the way I did it. It will save you alot of headache When I did mine I tried the regular hammer and wasn't getting anywhere. I then pulled out my air hammer and with a short squeeze on the trigger, they came right off. This is of course if you have the luxury of an air compressor in your garage. Here is the set I have. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194392 Share on other sites More sharing options...
December 31, 200618 yr comment_194398 on the early Z cars the main ball joint is pressed into the steering arm. Actually the tapered end of the ball joint is bolted to the steering arm, not pressed in. Once the steering arm is removed from the strut, you'll see a castelated nut. Remove this and give the end a firm whack with a hammer. That's all it took to get mine out. If I had planned on re-using them I would have used a brass hammer or drift to break it free. The hard joint to seperate is usually the connection between the tie rod end and the steering knuckle. This is where the tool you pictured may come in handy if you're looking to re-use it. If not, a pickle fork or the old kriol, hammer, heat and vise will do the trick. Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194398 Share on other sites More sharing options...
January 5, 200718 yr Author comment_194715 Thanks for all the replies and advice! Link to comment https://www.classiczcars.com/forums/topic/22804-ball-joint-extractor/#findComment-194715 Share on other sites More sharing options...
