The other method is to obtain the KD Spark Plug hole adapter. Threaded fitting which screws into the spark plug hole and accepts a threaded adapter for an air hose. Simply put the cylinder at top dead center, fire up the air compressor and use the 100+ pounds of air pressure to hold the valves up, while changing the springs.
It’s a lot easier if you park the piston at bottom dead center and then pressurize the cylinder. Finding exact top dead center without bolting a timing wheel to the harmonic damper is very difficult.
