January 16, 200718 yr comment_195726 ...http://www.holden.com.au/www-holden/action/modeloverview?modelid=4006HAHA check out pic 6!!anyway, that car is HOT Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195726 Share on other sites More sharing options...
January 17, 200718 yr Author comment_195792 akwikz, are you doing that in a kenmeri?? does the r200 pretty much bolt on or are there mods to make it work? also those are out of 280zx turbos right?? Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195792 Share on other sites More sharing options...
January 17, 200718 yr comment_195808 Yes, this is going into my Kenmeri. They are not a direct bolt in. You need to modify the rear mount some. It is not all that difficult though. The 280ZX turbo does have an R200 that would work, but it is one of those early 10mm bolt versions. The ones from the later Z31 300ZX and 200SX are 12mm bolt R200s. You will need the inner stub axles from an R200 out of a 280Z if you do not use C.V. joints on these later diffs. The inner stubs from your R180 are not compatible with the R200 so you can't just reuse those. Now, one other option you might have is a rare diff called an R190. These are a direct bolt in replacement of the R180, are substantially stronger than the R180, and will also bolt to your axles and the driveshaft. There are a few around, I may be able to help you source one if you'd like to go that route.Brian Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195808 Share on other sites More sharing options...
January 17, 200718 yr comment_195813 240kconv, i look forward to you proving me wrong a few years from now. btw, i hope everybody still got their k's:o in a few yearsI too look forward to proving you wrong (fingers crossed) :paranoid: , it's sad how many pride and joys get sold as unfinished project, even if they are finished they sell for sweet F A. That Anaconda Torana that was on the front cover of Street Machine is up for sale for $40k in Unique Cars. What a waste of money, must have cost at least $100k to build.I have the poster up in my garage with the words "what not to do" written on it.Sorry for the thread highjack. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195813 Share on other sites More sharing options...
January 17, 200718 yr comment_195835 Yes, this is going into my Kenmeri. They are not a direct bolt in. You need to modify the rear mount some. It is not all that difficult though. The 280ZX turbo does have an R200 that would work, but it is one of those early 10mm bolt versions. The ones from the later Z31 300ZX and 200SX are 12mm bolt R200s. You will need the inner stub axles from an R200 out of a 280Z if you do not use C.V. joints on these later diffs. The inner stubs from your R180 are not compatible with the R200 so you can't just reuse those. Now, one other option you might have is a rare diff called an R190. These are a direct bolt in replacement of the R180, are substantially stronger than the R180, and will also bolt to your axles and the driveshaft. There are a few around, I may be able to help you source one if you'd like to go that route.BrianIf you find a R190 open diff, there was a R190 LSD center for sale on ebay Australia recently. Didn't sell. Seller might be open to offers. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195835 Share on other sites More sharing options...
January 17, 200718 yr comment_195836 I thought that only the TT version of the Z32 had the R230 and that all others had an R200.Since the Z32 in Aus was never available TT then wouldn't it be an R200, with a revised rear cover for extra oil capacity and possibly a little extra heat dissipation?Anyone know for sure?btw, that rear cover is apparently the exact same part that NISMO was selling at some ridiculously inflated price! Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195836 Share on other sites More sharing options...
January 17, 200718 yr comment_195837 Re the 10mm vs 12mm bolts in R200's.Don't make the mistake of assuming that the later Z31 and 200SX units are 12mm versions - a some Z31's delivered in Aus have 10mm bolts.I've seen the occasional 12mm version in '83 280ZX 2+2 non-turbo cars in Aus so Nissan must have been upgrading a bit earlier than the intro of the Z31. Presumably they then used up whatever was in stock with the earlier Z31's.Anyway, it is not as critical these days. ARP make some really nice 10mm bolts that can provide MORE clamping pressure than the 12mm bolts from Nissan. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-195837 Share on other sites More sharing options...
August 11, 200816 yr comment_256116 Did Schwiplarkin ever get started on his project?a lot of people seem to come up with ideas but few ever act on them. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-256116 Share on other sites More sharing options...
April 18, 200916 yr Author comment_281088 sorry i havent posted here in a long time , but to answer 240kconvertible i have done two different projects and about to start my third. first i put a l28t motor in the skyline, the block cracked so i the did the v8 conversion with a four speed muncie tranny. it all turned out pretty good after a ton of work , i had to cut out 3 inches if the fire wall, use a front mount engine plate and made some mounting brackets off of the frame rails. i decided to use the stock rear end due to money and replace it when it breaks. ... well,, the first time to the track i blew it up right at the line. so now im starting the backhalf project. im putting a ford 9 inch with a four link setup. does anyone here know the gear ratio on the stock rear end? i will try to post some pics in the near future. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-281088 Share on other sites More sharing options...
April 19, 200915 yr comment_281179 Post some photos of your projects! Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-281179 Share on other sites More sharing options...
September 17, 201014 yr Author comment_331020 sorry i forgot to update you guys but you might find this interesting,,, Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-331020 Share on other sites More sharing options...
October 1, 201014 yr comment_332243 240kconv, i look forward to you proving me wrong a few years from now. btw, i hope everybody still got their k's:o in a few years heh heh Consider yourself proved wrong Mat Big Hat Two V8 K's completed . . . . . . poor Datsun purists Awesome Car schwiplarkin, was it down the 1/8th or 1/4tr mile? also what was all the smoke right at the end of the clip. Really glad to see your car completed. Link to comment https://www.classiczcars.com/forums/topic/22934-kenmeri-v8-and-9inch-swap/?&page=2#findComment-332243 Share on other sites More sharing options...
