Posted January 16, 200718 yr comment_195683 Hi all, who has built in the excentrical fron Camber Bushings and what is your experiance? Do they turn under pressure of hard cornering?Thanks for your answersRolf Link to comment https://www.classiczcars.com/forums/topic/22947-camber-bushing-kit-front/ Share on other sites More sharing options...
January 16, 200718 yr comment_195701 Doehring,I have no personnel experience with the kit you mention but, in all the reading and research I've done there has been no mentions of the adjustable bushing loosing adjustment under hard use. A number of members use them....hopefully they will add their 2 cents.Tom Link to comment https://www.classiczcars.com/forums/topic/22947-camber-bushing-kit-front/#findComment-195701 Share on other sites More sharing options...
January 16, 200718 yr comment_195702 Have them and swear by them. they dont move under hard cornering (i race my car) and they make fine tuning the camber possible. i have modified the cross member so that the lower control arms are mounted out further and this allows for a greater maximum camber but the camber kit finished the whole thing off because it allows you to dial in the amount of camber you want and be able to have the EXACT same amount on both sides of the car which modifying the cross member alone does not alow.paid not all that much (approx $100 AU) for the ones i got and would have to say that if you are trying to fine tune the suspension on your car then dont look past them.Tom Link to comment https://www.classiczcars.com/forums/topic/22947-camber-bushing-kit-front/#findComment-195702 Share on other sites More sharing options...
January 19, 200718 yr Author comment_196110 Thank you, you are really encouraging me! Link to comment https://www.classiczcars.com/forums/topic/22947-camber-bushing-kit-front/#findComment-196110 Share on other sites More sharing options...
April 29, 200717 yr comment_207619 I wouldn't overlook the discussion here http://forums.hybridz.org/showthread.php?t=120668 which discusses the possible down side to the bushings. Since the TC rod swings in an arch you get potential binding with the bushings (camber bushings or even stiffer polyurethane). The Canadian Atlantic Z Car club reports bump steer problems and proposed a solution to the harder control arm setup without going all out race front end.. http://www.atlanticz.ca/zclub/techtips/suspension/comprod/ball&socket/index.htm Link to comment https://www.classiczcars.com/forums/topic/22947-camber-bushing-kit-front/#findComment-207619 Share on other sites More sharing options...
