Email logins are now active ×
73 240Z Choke Problem
zman112233
I'm not sure what's going on so I thought I'd come to the experts. My car has a hard time starting (especially when it's cold) and when I choke up the engine it seems to make no difference. Should it be noticable? While I'm trying to start it or even once I get the car up and going moving the choke cable does nothing. I've traced it back to the carbs and everything seems to be moving ok so the cables aren't broken. Thanks for your help!
I looked in my Haynes manual and it looks like they are the stock carbs (There are two carbs with little black caps for putting oil in). (They don't have a butterfly). They have what looks like a piston that just moves up and down. When I pull the choke handle the cables move but the engine doesn't act any different and won't start any easier. What should I be looking for? When it's really cold my battery will usually die before I can get the car started.
Before we can give any advice, we still need to know whether your carbs are the stock '73 versions, or the earlier '70-72 versions that lots of '73s have on them by now. Because the systems are very different.
Take a look at the pictures at ZTherapy to help you identify which type you have. The terms to look for are 'round-top' and 'flat-top'.
If they are round-tops (with separate float bowls mounted on the sides of the carbs), the choke system is very simple. When you pull the lever, the fuel nozzle in the bottom of the carb should move downwards, which richens the mixture. So the first thing to test is to have someone move the choke lever while you watch the nozzles in the bottom of the carbs. Make sure that they move down when the choke lever is pulled, and also that they go back up when the lever is released.
For reference, the nozzle is just to the right of the vice-grips in the picture from ZTherapy linked below.
http://ztherapy.com/images/JapCarbPage_Pix/GasTubeDissassHelp.JPG
After the car has warmed up how does she perform? Does she start right away? How about after sitting for 30 minutes? When was the last time a tune-up was performed? Fuel filter, spark plugs, etc...??
  • Who's Online   0 Members, 0 Anonymous, 323 Guests (See full list)
