Badges Help
WW2Winger
Previous owner of my '71 Z removed the deck lid badges. I now have replacements, but when they painted the car, they covered the holes. From the underside, I can see that some of the barrel clips are still in position, just bondoed over to cover the hole. My fear is that if I try to re-drill these holes, the bondo and paint will chip out and make a bad place larger than the badge will cover. Even using a very small pilot drill bit could result in the patch chipping I'm afraid. If I purposely move over about 1/4 inch on all holes, would that be a terrible afront to the purist? I also can only see about three of these clips, so locating where to drill is another challenge. How would you suggest I proceed? Also, what size hole needs to be drilled to properly fit the new barrel clips? Thanks for the PM relies.
My preference would be to put the emblems in the proper position. If the metal is good and the Bondo is just there to fill the holes I'd definitely just get rid of the Bondo itself and not put any new holes in the metal. I'd start with a really small drill bit from the bottom and then carefully enlarge the hole from the top. Stop enlarging when you hit metal. Once you've got enough holes drilled you can figure out where the others go based on your new emblems.
I had a similar issue on my car. I used a very sharp pick with a right angle on it. Removed the inner panel from the hatch and very carefully scratched a tiny hole through the paint and bondo from underneith. Once I had a pilot hole in the correct place, it was easier to enlarge the whole to the correct size from the top.
Hope this helps,
Marty
You can also use a low adhesive tape, such as painters tape, on the outside surface of the hatch and this would help prevent the paint from chipping as you drill.
similar to an old woodworking tip of backing up the good piece of wood with a piece of scrap to prevent tearout of a drilled hole.
Thanks everyone for their advice. I now declare victory !! The badges are on!!! Since it is impossible to drill from the underside, no room, I had to do exactly as Marty suggested. It was tedious, but I finally picked enough body puddy from the back side to break through to the outside and give me a spot to begin drilling. Worked great and is in the original holes.
I have been reading this forum for quite a while and this is my first post. Thanks again to everyone for their input.
  • Who's Online   2 Members, 0 Anonymous, 770 Guests (See full list)
