E31 heads are probably the most valuable, particularly for racers. $375 is a reasonable price to get a valve job, new seals, etc. Try to avoid having the head shaved if at all possible.
John Coffey
johncof@veriomail.com
https://www.classiczcars.com/forums/topic/230-240-z-head/#findComment-488
John thanks for the information I am going to go ahead and repair this one. I have been on the road alot I apologize for not replying earlier. I will be in touch soon I have to put all the parts back together then start it up....
https://www.classiczcars.com/forums/topic/230-240-z-head/#findComment-489
  • 3 months later...
Hi Nick,welcome from another newbie,have a look at the base of the head where it meets the block just back from no.1 spark plug, you will see cast into the head a letter and 2 numbers,i.e. E31,E88,N42,N47,etc,etc.This tells you what type of head you have,you can also get a rough idea of how much has been shaved off the head by how close the bottom of the numbers are to the base of the head,not an exact measurement but something to check if you ever buy a 2nd hand head.Look for other posts for info on your head when you find the numbers.Hope this helps,Craig.
https://www.classiczcars.com/forums/topic/230-240-z-head/#findComment-491
  • 1 year later...
