On my early 260Z there were two fuseable links {wire type} the special cable was sold only by color code , green and black , I couldn't find any female spade terminals to fit in the local auto shops so i went to an auto electrician and he gave me a couple , he also made the point that if you are going to replace the cable make sure you make it exactly the same length as the length contributes to the melting point of the cable.
