Do any of you still have your original round key with an embossed "N" in it? (Has holes too) If so, could you post a picture. Better yet does anyone know where to get a blank N key? (w/o purchasing a set)
My 2/71 Z had such a key but the ignition barrel took a dump. Now all I can find is the ugly no-class keys you get at the locksmith.
Jim
https://www.classiczcars.com/forums/topic/23066-original-keys-pictures/
Your locksmith should be able to rekey the new cylinder to use the same old key. I had this done when the ignition cylinder failed last year. My old originals are retired and I use the new "no-class" for daily use. That is, if they were getting daily use these days.
Some previous discussion on keys can be found in this thread.
http://www.classiczcars.com/forums/showthread.php?t=20530&highlight=Keys
Keys vary between the date of production and market origin of your car.
The initial response from Bryan and others in previous threads does seem like your simplest solution.
Here's an alternative to the 'no-class' locksmith blank. I know these aren't the original type, and I'm not sure if they work on a 240Z, but these are what I use as spares on my 280Z (KEY00-00056) and my 810 (KEY00-00055). They're both still available through Nissan.
Just logged in... Thanks for the pics of the round key. This will help me show people what I'm looking for when asking around.
I have a working (but different) key for the ignition. My original "N" key was getting too smooth to unlock the doors so I retired it. Several years/moves later I can't find it. It just felt like more of a classic car when I used the N key.:)
Thanks
Jim
That key looks identical to my 240Z key, but flipped. The "grooves" in the key you showed are towards the left, whereas mine are towards the right.
Hopefully I will do this successfully but my key looks slightly different. I don't know if it is an age thing or not but my key is more squared off. It is original to the car and I have both sets. Carl
