Hey my signals in my Z just went dead. Totally and completely. I've been in cars where dead meant they would just come and and be solid, therefore prompting you to manually click it on and off.
Mine are dead. Turn the signal on and no light. Both were working great yesterday, no hesitation, no worries.
Any thoughts? Suggestions?:cry:
https://www.classiczcars.com/forums/topic/2310-turn-signals-dies-completely/
Same problems headlights just all the sudden went out the other night. Had to play with the switch.
Try checking all your fuses. And make sure all the connections on the switch look good. Sometimes if you jiggle or press on the connectors it will solve the problem. May need to buy a new switch. this is the second one I have replaced on mine already.
