Ignition Switch Wiring Question...
Dat240ZG
The problem may be in getting the "new" connector.
Other's who have tried to find them have found them to be somewhat elusive.
IIRC Dave Irwin (Z'sondabrain) had them for use when he manufactured the Parking Light Relay Harness. You might give him a PM.
The Connector is a 6 Spade Female connector (wide) and they're arranged 3 side by side, and two rows. I hope that explains it. Look at the back of your ignition switch and you'll see that only 5 of the 6 connectors actually get used.
HTH
E
