March 31, 200817 yr comment_242518 Good work Nigel,I'll get one of those made up for sure. Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-242518 Share on other sites More sharing options...
October 6, 200816 yr comment_262502 Hi, I'm still working on my brace, at last the weather is good enough to work outside. more pictures here http://noddle.110mb.com/Strut%20Brace/index.html Nigel Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262502 Share on other sites More sharing options...
October 7, 200816 yr comment_262630 I'm impressed with the amount of work you have done yourself Nigel, and you have the same brand welder as me yours is a little bit more powerful though, did you buy it on ebay? I'll be using your cad drawings shortly thats for sure. Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262630 Share on other sites More sharing options...
October 7, 200816 yr comment_262632 List of Mods I offered $5500 to complete(1) fitment of 300zx rear cradle, diff, suspension and brakes. The rear arches will need to be widened, and holes cut out for the shocks + mounting points as well as 4 new mounting points fabricated for the cradle & tail shaft connected. (2) fitment of R31 front crossmember, suspension, rack & pinion steering. The steering would need to be connected - column to rack, crossmember & suspension made to fit (3) fitment of engine and gearbox Mounts would need to be made for both. The front firewall and tunnel will need to be cut to allow room for the gearbox bellhousing. I would like the front cylinder of the V8 to be in line with the front axle line. I have placed a bare block inside the engine bay and it appears that it will fit quite nicely. (4) A pillar to B pillar support bar fabricated (5) Brake booster master cylinder & lines + upgrade to hoppers style kit for front end. As you can see there is a heap of work to be completed and SWR has asked for 2 months to complete it. Summernats is now off the cards for another year sadly. When it's completed I'm going to ask Alfa for verfication on weather or not it is the most modded C110 around I'm quietly confident he won't be able to find one with more mods :classic: Just for the record i paid twice that, Summernats is still off the cards for another year and Alfa never did show me a more modified K out there :cheeky: Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262632 Share on other sites More sharing options...
October 7, 200816 yr Author comment_262634 Just for the record i paid twice that, Summernats is still off the cards for another year and Alfa never did show me a more modified K out there :cheeky: Haha.. after a statement like that i feel the urge to tub the car Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262634 Share on other sites More sharing options...
October 7, 200816 yr comment_262681 I'm impressed with the amount of work you have done yourself Nigel, and you have the same brand welder as me yours is a little bit more powerful though, did you buy it on ebay?I'll be using your cad drawings shortly thats for sure. Yes, a ebay welder ($365 + freight), I wanted something that I could use with gas / gasles wire, and had some control over amperage / wire feed, most of the cheap ones were hi / lo and that was it. as i have said before, I enjoy working on my car, and I like to be able to say, I did it my self.. Nigel Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262681 Share on other sites More sharing options...
October 8, 200816 yr comment_262714 Haha.. after a statement like that i feel the urge to tub the car I'd love to see a tubbed K, can anyone photoshop it up? You'll probably need to get yours tubbed after you turn the boost up and get sick of wheelspining all the time Kent Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262714 Share on other sites More sharing options...
October 8, 200816 yr Author comment_262721 haha.. my car is almost tubbed.. rust wise (ok.. i joke!)..i have to keep telling myself.. i believe in IRS.. i believe in IRS... Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262721 Share on other sites More sharing options...
October 10, 200816 yr comment_262920 haha,Like the little train going up the hill...i think I can get traction, i think i can get tractionIf single swing arm irs is good for holdens and fords with 550nm it should be ok for the K, you'll just need to get some really stiff springs, perhaps some that were made in the viagra factory. Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-262920 Share on other sites More sharing options...
October 18, 200816 yr comment_263658 Another project finally finished, (to many to name), http://noddle.110mb.com/Strut%20Brace/index.html Nigel Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-263658 Share on other sites More sharing options...
October 18, 200816 yr Author comment_263666 looks great! Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-263666 Share on other sites More sharing options...
November 29, 200816 yr comment_267643 sorry if it's been mentioned but for a strut brace.... S13 silvia brace and all u need to do is 180 the strut top plates (cut and weld) and thanks to the import streetcar scene those braces are cheap and reddily available Link to comment https://www.classiczcars.com/forums/topic/23118-body-strengthening/?&page=4#findComment-267643 Share on other sites More sharing options...
