I have just purchased a 1971 240z with an l28 engine I found a vacume leak at the base gasket of my front su
now i have fixed it my z wont run right it is like it is running on 5 cylinders
but no mater what lead you pull of it makes no diference and it is blowing lots of black smoke i am guesing it is runing rich but i dont know how to lean it out? I know stuff all about su carbs (round tops)
if you could think of any other thing it could be please help?
https://www.classiczcars.com/forums/topic/23200-newby-with-an-su-problem/
i got it back from the mechanic today
he droped the needles a bit so it would not run so rich at idle
but it now runs lean at higher revs.
I was wondering if the 240z su' are to small for the l28 motor?
if so would a neadle change fix that?
Recently Browsing 0
