Posted February 9, 200718 yr comment_198630 An inquiring mind needs to know! Link to comment https://www.classiczcars.com/forums/topic/23221-rear-ss-window-trim-will-the-trim-from-a-280z-fit-a-240z/ Share on other sites More sharing options...
February 9, 200718 yr comment_198636 Yes, as long as the 280Z is not a 2+2 (If the 280Z has a back seat, some pieces will work, but not all).Will Link to comment https://www.classiczcars.com/forums/topic/23221-rear-ss-window-trim-will-the-trim-from-a-280z-fit-a-240z/#findComment-198636 Share on other sites More sharing options...
February 9, 200718 yr Author comment_198638 Thank you! Link to comment https://www.classiczcars.com/forums/topic/23221-rear-ss-window-trim-will-the-trim-from-a-280z-fit-a-240z/#findComment-198638 Share on other sites More sharing options...
