Posted February 10, 200718 yr comment_198776 Hey guys, is there an alternative/better replacement for the stock heater control valve for a 77 Z with factory A/C? After looking over this site and hybridz I found that a ford diesel or mack truck valve will work in a Z but the heater has to be cable operated. Mine uses vaccum like most other 77 and up Zs. The water leaks and soaked flooring routine is getting old. You can no longer order the vaccume heater valve through MSA, courtsynissan, or every dealer I called. Is there any alternative to this part? Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/ Share on other sites More sharing options...
February 10, 200718 yr comment_198788 I think the manual valve is still available. At least it was about two and a half years ago when I changed mine. 27190-N3100 was the number and it was only about 12 bucks. I don't know how that would work out with your cables, controls, etc. Mine is a 78 non-a/c car with an aftermarket a/c system so it still has the manual controls. Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-198788 Share on other sites More sharing options...
March 17, 200916 yr comment_277816 27190-N3100 no longer available. Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277816 Share on other sites More sharing options...
March 17, 200916 yr comment_277819 Seems to me that Zman of washington has advertized that he can rebuild them. Give him a try.http://www.zspecialties.com/ Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277819 Share on other sites More sharing options...
March 17, 200916 yr comment_277821 Since this thread (2 years old) I've had my old one apart and I'm pretty sure I could rebuild it. Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277821 Share on other sites More sharing options...
March 17, 200916 yr comment_277822 This topic popped up on a search.So i thought i'd update it.My 810 valve is frozen...... Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277822 Share on other sites More sharing options...
March 17, 200916 yr comment_277824 Z train said: This topic popped up on a search.So i thought i'd update it.My 810 valve is frozen......You should still be able to get the one for an 810 believe it or not. 27116-Q0100. Try that number. It's been a while since I bought mine but there aren't that many 810s around so I'll bet they're still available. Edited March 17, 200916 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277824 Share on other sites More sharing options...
March 18, 200916 yr comment_277882 Z train said: 27190-N3100 no longer available. Z train said: This topic popped up on a search.So i thought i'd update it.My 810 valve is frozen......Just bumping this to let you know that the heater valve for an S30 is different than the one for an 810. Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277882 Share on other sites More sharing options...
March 18, 200916 yr comment_277888 Well, what a revoltin' developement....I get the valve off and it is fine.I mean really free moving .Put it back in and let's go-right?Oh,no-this can't be that easy.The shaft that exits the heater box horizontally that attaches to the arm off the heater valve has a travel limit of less than a 1/4 inch.Something is jamming the door.So now the whole friggin box has to come out.(*^(&^%%*&!!!!! Link to comment https://www.classiczcars.com/forums/topic/23233-heater-control-valve-76-78-280z/#findComment-277888 Share on other sites More sharing options...
