Painting - Sanding between coats
biker
I know it is advisable to sand between coats with solid colours and the clear laquer but does this apply for pearlesant paints as well.
I have heard and read that some people do not sand metallic paints but only sand the clear lacquer.
I have just resprayed my car with a Green Mica but am not sure when to sand. Do I sand the paint back now before I apply the final coat of green?
Well, to be honest I picked up a white fender a while back with some very thick, hard paint on it. It was very rough, super bad orange peel. On a whim, I wet sanded with a scrap of 1500, 2000 then used a bit of rubbing compound. To my amazement the little patch I worked turned out to be a very nice white pearl. I wouldn't try this on a part I'd painted myself (not knowing how any other pearl/metallic would react) unless it was so bad as to require a respray anyway. The only way to be sure is to try it on a small patch that isn't normally visible.
