Posted February 11, 200718 yr comment_198830 I want to wire in a Kill Switch to my Ignition. There are two wires going into my Coil, can I run a switch to both of them (keeping the circuits separate) or should I ground the coil? Also, what gauge wire should I be using>Thanks in advance.ViparZ Link to comment https://www.classiczcars.com/forums/topic/23241-ignition-kill-switch/ Share on other sites More sharing options...
February 11, 200718 yr Author comment_198860 Here is a pic of the coil. The two wires I am talking about are the solid black wire and the black wire with a white stripe. Do not worry about the yellow wire, that is a ground wire which is how the kill switch is wired at the moment. What I am talking about is removing the ground wire and just putting a switch in either one or both of the black wires. Any suggestion for and/or against this. If I was only to cut one, which one? Link to comment https://www.classiczcars.com/forums/topic/23241-ignition-kill-switch/#findComment-198860 Share on other sites More sharing options...
February 11, 200718 yr comment_198865 As an experiment remove the wire for the battery side with the engine running. The engine should stop. If that's the trick, just put your switch on that. Link to comment https://www.classiczcars.com/forums/topic/23241-ignition-kill-switch/#findComment-198865 Share on other sites More sharing options...
