Posted February 19, 200718 yr comment_199787 Just finished with install of all new parts from MSA---For a early 73 240Z:Stock clutchPressure plateClutch collarTHROWOUT BEARING----:mad: Dust bootClutch master, hose, and slave were replaced a few months previously with new parts. Worked fine until the clutch disk lining finally wore out and it would slip under acceleration.A clutch disk alignment tool was used for the install.Bearing howels when clutch pedal is pushed in----sometimes quite loud and annoying, sometimes not so loud.Any fix short of taking it all down and redoing with a new bearing?Dissappointedly! :disappoin :disappoin :disappoin Jim D."Zup" Link to comment https://www.classiczcars.com/forums/topic/23334-fix-for-clutch-throwout-bearing-howel/ Share on other sites More sharing options...
February 19, 200718 yr comment_199794 Unfortunately no. How can you apply a fix when the part/area that needs fixing is completely covered by the bell housing? It does seem odd that a new bearing would make noise. Link to comment https://www.classiczcars.com/forums/topic/23334-fix-for-clutch-throwout-bearing-howel/#findComment-199794 Share on other sites More sharing options...
February 19, 200718 yr comment_199808 It would not be the first new bearing that I have seen bad. You may want to also inspect the fork the bearing rides on along with the pivot. Either could be bent enough to put a side load on the bearing. I have replacements for both along with the bearing. I will install them as I put the motor back. I do not want to drop the transmission once I am back together. Link to comment https://www.classiczcars.com/forums/topic/23334-fix-for-clutch-throwout-bearing-howel/#findComment-199808 Share on other sites More sharing options...
February 19, 200718 yr Author comment_199812 Thanks for the replys--- I knew the answer-----wishful thinking?? I will reinspect the fork and pivot on disassembly. They looked fine. I will also be looking for rough spots on the input shaft. I suspect that I have been victimized by a "bad in the box" bearing as a7dz stated. It does happen---but :hurt: WHY ME? Jim D. "Zup" Link to comment https://www.classiczcars.com/forums/topic/23334-fix-for-clutch-throwout-bearing-howel/#findComment-199812 Share on other sites More sharing options...
