Posted February 21, 200718 yr comment_200013 I,m thinking about putting in some sylvania silver star sealed beamed headlights on my1976 280Z. I still have the original headlights on it and the deer are getting too close before I see them! Does the headlight harness upgrade that VB sells still give you control of your headlights on the stock controlsON/ OFF Hi low beam? I called them and they said they would get back to me. It looks very similiar to the ones that were selling on this site. Thanks. Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/ Share on other sites More sharing options...
February 21, 200718 yr comment_200015 You may have to build it yourself if you want it right. Dave's custom harnesses only fit on 240Zs, the 280Zs have different connectors. And here is a thread that points out that the kit from VB (now Black Dragon) doesn't fit either.http://classiczcars.com/forums/showthread.php?t=18141 Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/#findComment-200015 Share on other sites More sharing options...
March 28, 200718 yr comment_203857 I'm up the road in Austin... Same problem with deer. =:^0Just did the combo switch and wiring harness upgrade. wow oh wow...Got the ZX alternator coming. How did the silver star lights work out? Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/#findComment-203857 Share on other sites More sharing options...
March 28, 200718 yr comment_203866 You may have to build it yourself if you want it right. Dave's custom harnesses only fit on 240Zs, the 280Zs have different connectors. And here is a thread that points out that the kit from VB (now Black Dragon) doesn't fit either.http://classiczcars.com/forums/showthread.php?t=18141Dave can build them for a 280z (you just have to find spare plugs or cut your harness) in order for him to build it. It can be done and is a good upgrade to save your wiring system. Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/#findComment-203866 Share on other sites More sharing options...
March 31, 200718 yr comment_204224 My headlights got progressively better with each mod this week.1) Combo switch rebuild (amazing jump in light output)2) Dave's wiring harness (even better)3) Turbo ZX Alternator (brighter still)4) Sylvania Silver Star Headlights (bright yellow to bright white)At this point the visibility is on par with a new car.My motor started running smoother after the alternator upgrade. Must be better spark somehow. Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/#findComment-204224 Share on other sites More sharing options...
April 9, 200717 yr comment_205287 Maybe I should ring in at this particular time. I CAN make a harness for your Z but There is 2 ways to go about it. 1)Hard wire, which requires you to cut off your white, round headlight plugs and hardwire my harness into yours.2)Cut off the headlight plugs from a donor car and send them to me with all the needed measurements (I'll get into that later if you email or PM me) and I'll build you a plug and play harness that requires NO cutting of YOUR haenss or system.The 280Z harness requires a lot more Labor and supplies to build so the price is $150 but you won't be sorry when it comes to the results of the harness.Your fusebox and combo switch will thank you. You'll get NO sympathy from ANYONE here if you use the VB/Black Dragon after we've warned you.Hope this helps a little,Dave. Link to comment https://www.classiczcars.com/forums/topic/23366-headlight-harness-upgrade/#findComment-205287 Share on other sites More sharing options...
