Email logins are now active ×
restoration of steering wheel
bduprees
SportZ had a great article on how to do this. I followed it and came out with pretty good results :)
You might want to call them and ask for a re-print of it; that's what I did and ended up subscribing :)
Anyway, to just do the steering wheel, not re-painting the spokes, you lightly SOS-pad the plastic while soaking it in warm water. You don't want to take off too much of the "patina" (years of grime from hands using the wheel), because that's what makes it look more like wood :) Basically, you're trying to remove the gloss and even out the finish. When it's all dry, you lacquer it with a semi-gloss clear lacquer. I couldn't find semi-gloss and had to use gloss, but it looks fine. BEing the nut that I am, I put about 15 thin coats of the stuff on ROTFL
But seriously, this is an awfully simplified explanation of what to do. Call SportZ and ask them for a re-print of the issue that has the article in it :-)
This would have to be the simplest repair/mod/update you can perform on your zed.
Don't be deterred as it really is easy!
Easiest way is to use steel wool and detergent [soapy water] to clean down the rim of the wheel.
This will remove the years of dirt and grime.
Any bumps or nicks can be filed down with file or sand down with fine emery.
This smooth sanding will eventually bring the wheel looking similar to raw wood even though it's plastic.
All that is required to complete the job is to mask off the spokes and apply as many thin coats of semi-gloss spray varnish as you desire.
You can change colours if you desire by using wood stain before you varnish.
