Should a Strut Bar "Push" or "Pull"
Victor Laury
I have strut bars on both my Z car and 510, and everytime I set it up I wonder...
Is it better to tighten the bar so it is pulling in, as in pulling the towers toward each other or, pushing out, as in pushing the towers further away from each other. It would seem to me that either way will add support to the suspension but, I wonder wich is better?
This is not a test question.
Victor, does the static position of the mount change when you jack up the car? Say you adjust it to be slack, neither push or pull, then jack up the car. If the bar is now tight, figure out if it's pushing or puling, then set the car back down and adjust the bar the opposite direction.
I don't know that this method is "correct" but it seems to me that is makes sense. FWIW.
I would say that the strut towers are more likely to sag towards each other due to body flex, than away from each other. Therefor, adjusting them to have a tiny bit of pressure outwards should make them the most efficient. You might want to take a measurement of the towers according to the FSM and see if the distance between them is too big, or too small. All of the dimensions are on one page in the body section.
Jeff is partially right. With our old cars and especially with high spring rates the strut towers do flex in when the car goes over bumps. That's kind of what you'd expect to happen. Cornering is different.
When cornering the load is pushing on the bottom outside of the tire and that then pulls the top of the strut outward. I read this first in an old Porsche Owners Club magazine where they had done some testing with a tattle tale dial indicator and measured the flex before and after installing the strut tower bar on a 944. This was also on a BMW racing site, and for the life of me I can't locate that site anymore. May just not be on the internet anymore.
When I set mine I always preload a little tension in the bar. Realistically I don't think it matters too much one way or the other though...
I think there are two functions to the strut bar that I can see:
1) maintain the relationship between the left and right side suspension and therefore avoid bump-steer-like effects due to eaach side flexing independantly (note: this is not the classical bump steer we normally refer to but the effect is the same)
2) reduce the positve camber on the outside wheel that would be induced during hard cornering. Accomplished by transfering the load to the inside (less loaded) strut tower
In the case of '1', it doesn't really matter if the bar is preloaded one way or the other
In the case of '2', preloading it in tension would be more effective at having the inside torsional stiffness help the outside...preloading it in compression would help the outside by virtue of the outside already be in the loaded position during transients.
Not being a terribly consistent driver, I doubt I could ever tell the difference. I would aim for whatever setting gives me the best hood to fender gap :D
Al
  • Who's Online   0 Members, 0 Anonymous, 466 Guests (See full list)
