  graham53 said:
I have bought this brake kit
http://www.thezstore.com/page/TZS/PROD/PBC13/24-5707
And now need front hubs
Can any one help me locate these
Thanks
Here's a quote from the ad you linked:
You can call a Motorsport Sales Technician, who will be happy to search for a set for you, or you can locate your own.
So, with that in mind, I'm going to throw out a crazy idea that maybe if you call and talk to a Motorsport Sales Technician, that technician may be able you find the hubs you need.
I have a penchant for the obvious.:D
Now if there is some reason you do not trust the help you could receive from Motorsport, you could look at ads on any number of Z car websites to find auto dismantlers/junkyards/whatever you want to call them that have early Z cars.
Thanks
That is the obvious but they are no help. They said they dont have any and i was on my own so i thought i would ask here. the Pick Your Part is a good idea but i am on the east coast. Have called several local yards but no luck, but will keep trying
  graham53 said:
Thanks
You might want to bookmark this list: http://www.zcar.com/links/index.php?ParentID=6
You might try getting in touch with Roger. He's busy, so you have to be persistent. You're not going to have much luck going to a junkyard unless you drive up to Virginia.
I would try the Zbarn-It's a one person operation, so leave a message and you will get called back. There is more stuff available than is listed on the website, so call, even if the stuff you need isn't listed.
http://www.zbarn.com/
