Electrical Problem
omega Z
  • 1 month later...
That problem has been resolve, it was, a burnt fuseable link and some burnt wires. I had to have it rewired.. We got every thing working but now the head lights don't work, it strange the wipers, parking lights, dash lights, signal lights all work. I know it can't be a bad switch I replaced it two years ago.. I got it from Motorsport and it was expenisive..Any suggestion..Omega Z
you can see if it's the switch by running a jumper on top of the combo switch, connect the red wire to the white/red wire via a jumper. the lights should come on. If they don't, the switch is fine and the problem is else where.
Over on the Hi/Lo switch (T/S ) the high beam wire is the red/white and the low beam wire is the red/black. The middle wire on the white hi/lo switch is a ground wire, if there is not a ground present, the problem is there. Make sure that the black wire is getting a good ground from the combo switch, check the middle connection.
Also check the red wire on the combo switch to make sure it has power from the fusebox.
Dave.
  • Who's Online   2 Members, 0 Anonymous, 503 Guests (See full list)
