Posted March 9, 200718 yr comment_201647 Okay so Sblake and I have been shooting PM's back and forth about my fuel system and troubleshooting but now I have an even bigger problem that I'd like some input on. My Engine is locked, the tranny is in neutral and the starter is out. the battery has a full charge and we cant crank it by hand. Now heres the kicker. If I was to wait about 2-4 hours I could go back out there hook everything up and it will try and turn over but no gas. And that is why I have been chatting with Sblake. Anyone got any ideas?Christian Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/ Share on other sites More sharing options...
March 9, 200718 yr comment_201649 Pull the dipstick. Is it over full? Does the oil smell like gas? Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201649 Share on other sites More sharing options...
March 9, 200718 yr comment_201652 Need background. the engine is frozen up from setting ? If so don't try the starter . have you put any oil in the cylinders to help there ? You are not affording much info . Have you tried the starter or not ? You can always put the trans in gear and see if you can brake it loose . the thing is if the rings are rusted to the bore you can damage the piston forcing the issue. Also the valve stems could also be rusted. If you stick a valve spinning the engine with the starter you would bend some valves and maybe punch a hole in a piston . Gary Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201652 Share on other sites More sharing options...
March 9, 200718 yr comment_201664 Is your head gasket OK. The bores could be filling with water/oil preventing you from cranking the engine. Probably drain out into the oil pan if left standing. Check your oil level. As has been said, bit more info needed. Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201664 Share on other sites More sharing options...
March 9, 200718 yr comment_201667 Try removing the plugs to relieve the pressure. Try it without using the starter. If you can't then something else is freezing up the engine. Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201667 Share on other sites More sharing options...
March 9, 200718 yr comment_201669 Cyl pressure too high? The two to three hours to leak down...then it works.. Take out the plugs one at a time and try, if yes, install a compression tester and try. If I am right, you will probably find the issue in the valve train Will Oh sure Ramses, read my mind and type a shorter version! Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201669 Share on other sites More sharing options...
March 9, 200718 yr comment_201678 if its efi and an injector is leaking it may fill a cylinder with fuel stopping you from cranking it over, but you should post more info about what sort of engine you have, whether its efi, did you just do any major work to it (head off, etc)... Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201678 Share on other sites More sharing options...
March 9, 200718 yr comment_201685 I am with the remove the plugs idea and see if there is something in the chamber(s).Beware, water and fuel will not compress like air / fuel spray. Hydraulicing (spelling?) an engine can have BAD results.Keep us posted... Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201685 Share on other sites More sharing options...
March 9, 200718 yr Author comment_201735 Okay more info. I just replaced the head gasket and head. Gasket was bad an head was cracked, Already took the plugs back out. But I think that I have a slight problem. The oil does smell a tiny bit like gas. So what should I do now? Link to comment https://www.classiczcars.com/forums/topic/23534-engine-locked-need-help/#findComment-201735 Share on other sites More sharing options...
