Posted March 15, 200718 yr comment_202393 I have searched all over for the blower motor to switch wiring harness jumper . My manuals do not cover it or any thing Ive come across . I've replaced the entire loom , rebuilt the combination switch (signal & wiper),added headlight relay, electric cooling fan & relay , etc. The problem is the used loom is missing the jumper (6 blade to 6 blade + ?) from motor to switch. I would really appreciate a diagram , picture , or schematic that details it out for me ! Thanks in advance for your time. Tom Link to comment https://www.classiczcars.com/forums/topic/23600-blower-motor-to-switch-wiring-1973/ Share on other sites More sharing options...
March 31, 200718 yr comment_204233 I'm guessing the car is not air conditioned. I just happen to have a '73 blower motor on my 'puter desk as we speak:rolleyes: It is a 6 pin plug but it only uses 4 pins 1. RED is the +ve supply to the blower via a 30A fuse. 2. YELLOW is the HIGH fan speed wire, connects to the BLACK wire at the motor resistor pack [ground side of the blower motor]. 3. GREEN wire is the MEDIUM fan speed wire, connects to the mid-point of the resistor. 4. WHITE wire is the LOW fan speed wire, connects the the end of the resistor. Hopefully, you can now cross reference these wire functions to the connector at the switch. [THAT piece of my Z could be ANYWHERE:surprised] Pics. attached hopefully show some detail: - [if you need bigger pics. let me know.] Link to comment https://www.classiczcars.com/forums/topic/23600-blower-motor-to-switch-wiring-1973/#findComment-204233 Share on other sites More sharing options...
May 23, 200717 yr Author comment_210390 Thanks for the help.built the jumper worked first try !! Link to comment https://www.classiczcars.com/forums/topic/23600-blower-motor-to-switch-wiring-1973/#findComment-210390 Share on other sites More sharing options...
May 24, 200717 yr comment_210492 Excellent!!Nice to here you had a successful outcome! Link to comment https://www.classiczcars.com/forums/topic/23600-blower-motor-to-switch-wiring-1973/#findComment-210492 Share on other sites More sharing options...
