Posted March 16, 200718 yr comment_202543 HelloThis is a very basic, newbie question (I think):I have never done an oil change on a 240Z before, but have done plenty on Hondas. Hondas have an aluminum crush washer for the oil pan drain bolt. This is a one-time use washer that you replace each time you drain your oil.Do Datsun 240Z's have a similar washer that needs to be replaced?Thanks. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/ Share on other sites More sharing options...
March 16, 200718 yr comment_202546 Nope! Just a straight up big fat bolt. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202546 Share on other sites More sharing options...
March 16, 200718 yr comment_202548 Nope! Just a straight up big fat bolt.Sorry to disagree, but there is a copper crush washer that should be changed with your oil change. These are still available at Nissan Parts. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202548 Share on other sites More sharing options...
March 16, 200718 yr comment_202552 ...huh. Mine must've disappeard long ago.Well, now I know. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202552 Share on other sites More sharing options...
March 16, 200718 yr comment_202553 I was using the copper washers but found that they seeped. I went to ACE hardware and they have fiber washers specificly for drain plugs . No more drips. Gary Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202553 Share on other sites More sharing options...
March 16, 200718 yr Author comment_202554 Sorry to disagree, but there is a copper crush washer that should be changed with your oil change. These are still available at Nissan Parts.Called the local dealership, and they do offer a copper washer. I don't think it's specific to the 240Z. Most likely a universal washer for all Nissans.I'll try this out, and if it seeps, I'll try the fiber ones like Beandip recommended.Thanks for the help. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202554 Share on other sites More sharing options...
March 16, 200718 yr comment_202559 All my Nissan's have a copper washer. Z's, 240SX and Xterra. If the underside of the pan plug and the area around the pan hole is not buggered up, the copper washer will seal every time and not leak. I do wish the Z pan plug had more of a washer incorporated into the hex. The S13 and the X have much better pan plugs than the Z. I use one new OEM Nissan washer after about 4 oil changes. I've tried auto parts and hardware store versions and they are too thick. The Nissan washer has a certain crush factor that when tightened conforms to the plug and the pan surface. But after awhile it kind of tears/shreds and then its time for a new one. FWIW, I work at a truck dealership and we use coppers on all the major engine's pan plugs also. Mack, Cat, Cummins, Detroit Diesel and Mercedes Benz. Chris A. P.S. Courtesy Nissan in Texas can get you some. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202559 Share on other sites More sharing options...
March 16, 200718 yr comment_202561 What causes the copper washers to seep is that sometime in the past the plug was installed without the washer creating gouges in the mounting surface. As long as that has never been done the copper washer will seal fine. I change them with about the same frequency as Chris. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202561 Share on other sites More sharing options...
March 16, 200718 yr comment_202562 Dan is correct the drain plug does use a copper washer. I think this is the part number 11026-61000. It should be noted new Nissan's have a smaller diameter drain plug so one size does not fit all. I have also heard of people using a plastic washer. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202562 Share on other sites More sharing options...
March 16, 200718 yr comment_202563 I don't know, plastic or fiber + heat.......From a similar thread last year:Nissan still stock them. Part no. 11026-61000. As I recall, they're under two bucks. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202563 Share on other sites More sharing options...
March 16, 200718 yr comment_202567 Stephen and Zulaytr are both correct. From:http://www.courtesyparts.com/s30_oil.htmlChris A. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202567 Share on other sites More sharing options...
March 16, 200718 yr comment_202568 You can anneal the copper washer by heating them dull red with a propane torch then cool. either air or water copper doesn't care. You then have a nice soft washer for reinstallation. copper work hardens so when tightened a few times it gets hard. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/#findComment-202568 Share on other sites More sharing options...
