March 16, 200718 yr comment_202582 Fumoto engine oil drain valve-bottom right-any ideas, thoughts or opinions on this? Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-202582 Share on other sites More sharing options...
March 16, 200718 yr comment_202583 I've been using a "plastic" washer for years with no leaks or other problems. I found one that fit rather snugly over the drain plug threads so it doesn't fall off when I do an oil change. I have always been afraid to use those oil drain valve things because it looks to me they could get broken off or accidentally knocked open if you run over something on the road or even take a unplanned excursion through the weeds.The Z has always been the easiest oil change of any car I ever owned. I can reach both the filter and drain plug from the top side. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-202583 Share on other sites More sharing options...
January 27, 201015 yr comment_307628 I just got a set of 10 copper washers off eBay. Good deal? At the rate I change the oil (annually) it'll last me for the next 10 years. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307628 Share on other sites More sharing options...
January 27, 201015 yr comment_307630 It don't mater what it is made of it is a crush washer just get one the same size as the original, and check what the torque is for the washer it needs to crush to seal the surfaces and to tight and it can damage the mating surfaces. I get mine from the Toyota Dealer they have these nice, ceramic nylon ones:laugh:. They happen to be the same size as my Toyota and they give me them for free when I buy my Toyota oil filter. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307630 Share on other sites More sharing options...
January 27, 201015 yr comment_307660 I just got a set of 10 copper washers off eBay. Good deal?....Tough to say without knowing what you paid for them..... 10 of the OEM ones would be about $24.50 total incl. shipping from NissanParts.cc. Edited January 27, 201015 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307660 Share on other sites More sharing options...
January 27, 201015 yr comment_307663 Sorry... $11 delivered. Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307663 Share on other sites More sharing options...
January 27, 201015 yr comment_307665 Sorry... $11 delivered.Not bad. The OEM ones are are somewhat pricey for washer. I bought mine when I worked at ACE Hardware. I think they were something like 54 cents ea. with the employee discount Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307665 Share on other sites More sharing options...
January 27, 201015 yr comment_307690 Fumoto engine oil drain valve-bottom right-any ideas, thoughts or opinions on this?I have used this valve for over twenty years! It is a Cam Locking Ball Valve and it does not leak. Great Invention! I highly recommend!! Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307690 Share on other sites More sharing options...
January 28, 201015 yr comment_307711 I have used this valve for over twenty years! It is a Cam Locking Ball Valve and it does not leak. Great Invention! I highly recommend!!I know two cars we put that on. the threads were damaged so we mounted a valve because we would strip it out bad the next time. It's not bad, but I'll stick with the tried and true plug (unless I strip the pan). Link to comment https://www.classiczcars.com/forums/topic/23613-oil-pan-drain-bolt-washer/?&page=2#findComment-307711 Share on other sites More sharing options...
